dperkinstx
Jan 08, 2015Explorer
Edge Trim Sealant
I want to re-do the seal all around the edge trim of my '94 Minnie Winnie. Winnebago has a part #072889-20-000. Is there something at Home Depot or Lowes that I can used that works as well?
TYPES OF SEALANTS
There are currently three basic types of sealants used on the exterior of Winnebago Industries produced vehicles; silicone-based, urethane-based and solvent based.
Because different based sealants are not compatible, it is imperative that the proper product is used when resealing. In other words, if a non-compatible sealant is used, the two materials will repel each other and allow moisture and debris to penetrate the seal. Ascertaining whether a sealant is silicone, urethane or solvent based can be difficult for someone not knowledgeable or proficient in resealing. (hense the caulking call out sheets)
As a general rule, urethane sealants cure to a more firm and rigid form. Solvent-based sealants can cure to either pliable or firm states depending on the particular sealant. Silicone sealants tend to remain more pliable. Silicone sealants will retain a higher gloss after curing. Urethane sealants are colored. Silicone can be clear or colored. Solvent based can be clear or colored. The following is a current list of products available from your Winnebago Industries dealer.
We hope this information will be helpful. If you have any questions or require service to your coach, we suggest you contact your dealer.
