et2
Aug 13, 2013Explorer
sljkansas wrote:
Do you have an outside shower? If you do check to see if the valves are closed. If they are both open the cold water will calculate with the hot.
I don't have a problem with hot water. I just don't think the electric is working because of the late night propane kicking on. None of my other propane/elect water heaters ever fired at night.
I guess I will just turn the electric on alone.if If it worked I question why the late night propane coming on. It should hold temp with the electric as the water isn't being used.
38,769 PostsLatest Activity: Apr 04, 2026
