dougrainer
Aug 14, 2013Nomad
BigRabbitMan wrote:et2 wrote:
I have 2 switches in the control cabinet at the front of he MH. One for propane & the other for electric. There is no way to tell the electric is on ( no red light or else). There is a red light that would indicate a misfire on the propane but otherwise it's not lit.
Thanks for the replies!
It is possible that your problem is simply the temperature settings on the two modes of heating. If the propane side is set to take the water to a higher temp than the electrical side, it will periodically turn on even if the electrical side of working fine.
If that is the problem, just lower the temp setting on the propane side or increase the temp setting on the electrical side (if adjustable).
NO Water Heater from the factory has an adjustable tstat. You can purchase some as aftermarket install. Atwood LP/120 Water Heaters built in the past 10 years, use the SAME (140 degree) Tstat for both modes. Suburban Water Heaters use 2 different Tstats. An LP side and a 120 side, but BOTH have the same temp rating. Doug
38,769 PostsLatest Activity: Mar 31, 2026
