Old-Biscuit
May 13, 2013Explorer III
Hott Rod & Lightning Rod are two aftermarket electric heat elements that are installed in the WH tank drain and then plugged into an AC outlet.
They are small wattage and can help maintain hot water......by themselves they have a very long recovery time.
Both Atwood & Suburban void warranties on WH if used.......so say goodbye to your 2 yr. warranty.
'Anode' is a sacrificial rod used in Suburban WHs.
Atwood WHs don't use/need them.
38,766 PostsLatest Activity: Jan 10, 2026
