Rick Jay wrote:
DrewE, while I agree with most of your summary, I believe there CAN be a situation where a male plug WILL heat up. Let's assume there's 15Amps flowing into the 20A male plug and 25A flowing into the 30A male plug. Both 20A and 30A breakers think everything is OK and will not trip. However, the neutrals to each plug are connected together and there is no way to determine HOW that 40A of combined current will get back to the neutral in the power pedestal. Maybe it'll split 15A/25A just like it did through the hots OR maybe it'll flow 10A through the 30A neutral and 30A through the 20A neutral. There is no way to be sure, and since the breakers don't protect the neutral wiring, there definitely could be an overheating and potential fire hazard issue should this occur.
I mostly agree with this, and that's one reason why I don't like or recommend these. There is in fact a way to determine how the current will split (namely, through application of ohm's law), but the impedance differences could very easily work out such that it's not splitting the way it ought to for safety. It's much more certain to be problematic if there's a poor or broken neutral connection. In the case of an open neutral, where you'd get no power without the cheater, you get power with a reasonable possibility of fire on the side...not a very comforting tradeoff.
It was perhaps a poor choice of words, but I meant "hot" in the sense of "electrically live" rather than in the sense of "having a high temperature" with the comment you're referring to. With proper wiring and no 240V appliances in the RV, there's no way one of the two male plugs to be electrically live if it's unplugged and the other one is in use. If either of those preconditions conditions is untrue, then there could be the possibility a (dangerous) live male plug.
