nemo45
Aug 13, 2013Explorer
racerchaser wrote:
1. Typically, rain will not pool on an electric awning as they have an ability to 'Kneel" at one end with the weight of water.
2. Awning manufacturers tell you not to tie down your awning for the same reason ladder maker put so many decals on their product.
3. If you use common sense there should be no problem.
4. If you have a problem, see #3.
That's not true. I've had it pool on mine, and it was so heavy that it bent the roller on the awning so much that it would not retract. I had to replace the awning. The awning hardware was ok. It can rain so hard that even the "kneel" mechanism will not remove it fast enough to stop it from pooling. I'm here to tell you it can happen.
