burlmart
Jun 15, 2015Explorer
i think on ours, if the house disconnect is toggled to STORE, step will not work when turning its switch (with a white light) to ON. but chassis ignition with door closed overrides all this and step goes in.
*** EDIT CORRECTION ***
i think on ours, if the house disconnect is toggled to STORE, step will not work when turning its switch (with a white light) to ON. AND, turning on engibe with door closed DOES NOT overrides all this to force step to go in.
but w/ house disconnect toggled to USE, and step is OFF (no white light), turning engine on w/ door closed will force step to go in.
38,766 PostsLatest Activity: Jan 10, 2026
