BB_TX
Aug 26, 2013Nomad
Two Jayhawks wrote:katysdad wrote:
No, you will still only have ONE 20 amp outlet feeding the a/c. It will not combine the two outlets to up the amp supply. One side feeds one side of the panel box the other plug the other.
Well if I end up with a clean 20 amp for each side isn't that still more than I would have when I am @ a RV park that only has 30 amp? Anyone can run one AC no problem with 30 amp right?
You will have 20 amps to half of your circuits and 20 amps to the other half. The AC is internally connected to one of those circuits. So you will still only have 20 amps to which ever circuit the AC is on.
But you should be able to run a 15k AC on 20 amps with no problem as long as you do not run much of anything else.
