RoyB
Aug 26, 2013Explorer III
I'm guessing the only real advantage of using one of those cheater boxes is that both legs of the RV50A circuit will be plugged into a separate 20A circuit. This should allow both air conditioners to work just fine on a RV50A setup if nothing else is drawing alot of current.
I couldn't find a diagram doing a quick search using the 20A male plugs but it would be wired the same as this diagram using the RV30A male plugs. Each separate 20A male plug would feed each of the two legs of the RV50A female connector.
Roy Ken
