wolfe10
Aug 27, 2013Explorer
Passin Thru wrote:
We have 2 30 amps running to a splitter and plug the main 30 amp of ours into it. Works effectively so don't worry about what people say won't work. You have 40 AMPs going to a 30 amp circiut. It will work.
Not sure I understand. Your coach is wired for 30 amps and you use a splitter??? Sure hope you verify that both "sources" are from the same side of the building breaker box. And, what is the advantage.
And assuming the OP has a coach wired for 50 amp coach: Do you mean 40 amps going to a 50 amp circuit?
And, I agree with you that he can do this with the reservation that each "source" only provides 20 amps. And, as I stated earlier, if A/C, refrigerator and charger are all on the same source/hot, adding the splitter will not help.
