wa8yxm wrote:
lfeather wrote:
I understand where the neutral wire is connected to the 50 amp rv plug, but can someone please explain what the neutral wire is connected to on the other end of the wire? The ground is connected to "earth" right? Is the "neutral" connected to earth too? Thanks for any clarification.
Larry
Using ASCII it is very hard to draw a proper transformer.. But I will try
\||/-------- L1
\||/________ Neutral
/||\________ L2
P S
R E
I C
M O
A N
R D
Y R
. Y
The Primary winding (\/\/\/\/) is connected to the high voltage mains either above or underground
The Secondary winding is the 240 Volt winding that provides power to, for example, your house
The Neutral, is the center tap on the 2ndary winding.
Why is it called neutral?
Well. That is a good question, but if the two legs are PERFECTLY balanced, Say two Advent 1500 BTU Air conditioners, both in identical condition under identical conditions, and NOTHING else on in the coach, Then L-1 is providing 13.5 amps to the air conditioner (one of them) so is L-2 (to the other) but due to the phasing of the two legs.. The neutral is carrying a grand total of nothing at all, if it were to break, you'd never know. OF course that only applies in a perfectly balanced system (not practical)
Why is it done this way?
Let's say it's 1,000 feet from you to the transformer.. That is a long haul and a lot of voltage drop from the aforementioned 13.5 amps, since it has to travel not 1,000 feet, but 2,000 feet, (out and back)
But with the 240 volt system, you effectively do not send it back, Since it travels out 1,000 feet, then runs through the other A/C and travels back.. So the voltage drop is now divided into two halves.
So if it is say a 5 volt drop, each way, (10 total) if you had just one A/C running and 120 volt at the transformer, you'd have 110 at the A/C.. but with two of them running they each loose half, so you have 115 at teh A/C. Much nicer.
Now.. if you are a bit confused.... This is taught at the college level. I took the course (like 40+ years ago) and recently took a refresher (like 7 years ago) So do not feel bad.. Some of the concepts I figured out in that refresher had me a mite confused for the better part of 40 years. (But they are not covered here)
That appears to be a course that would not have a lot of coeds in attendance, so that a course I would have actively avoided.
