2chiefsRus
Jul 16, 2016Explorer
if your site is close enough to the next site, the easiest thing to check is to plug into another pedestal and see if the problems go away. Could just be a power problem at the campground pedestal.
Could also be the pop out breakers on the inverter. They look like little fuses that will pop out and then need to be pushed back in to reset them.
What type of inverter do you have?
Another thing you could try is to fire up the generator and see if everything works that way.
