Bobchambe's avatar
Bobchambe
Emergency 4 way Flashers
I have a 1996 Georgie Boy Cruise Master on a Chevrolet P-30 chassis.
My directional lights and brake lights work fine, but the 4-way lights do not flash, only stay on.
I have tried to locate a second flasher but have not found one. The directional light flasher is in the fuse panel under the hood, top drivers side.
I tried to find a flasher under the dash around the steering column but could not find a flasher.
I was hoping someone with the same coach has an idea?
Thanks, Bob
  • Thank you for the replies.
    At 6'2' and 220lbs., I may have to pull the drivers seat to look up under the dash. LOL
    I have felt around under there and tried taking pictures but haven't been able to find it.
    I will keep searching.
  • Gjac's avatar
    Gjac
    Explorer III
    I have the same year and chassis and mine was difficult to find also, it is way up under the dash on the left side of the steering column. You have to lay on your back and look way up with a flashlight.
  • Have you searched for information on the chassis. That may tell you where it is.
