jaycocamper6230
Apr 14, 2019Explorer
RLS7201 wrote:
Close to the two battery banks is a black box called a Battery Control Center (BCC), manufactured by RV Custom Products. In the BCC, behind the circuit board, is the isolator relay. It's the silver one. It's probably your problem. On the back side of the BCC cover is a wiring print, that shows how the isolator relay connects the two battery banks together when either battery bank reaches 13.2 volts. Your coach DOES charge the chassis battery when plugged in. Advice about your charging system from non Fleetwood owners is usually incorrect.
Richard
so you're saying take the entire fuse panel out because there is no isolator relay there
38,782 PostsLatest Activity: Aug 23, 2026
