grldst
Aug 03, 2021Explorer
If your fuel tank is low and you’re on an uneven surface it’s possible you have sucked air from fuel tank or bad fuel (water or other contaminants) from the bottom of the tank. It’s possible your gauge is off a bit. On my diesel motor home my gauge will show a quarter tank one minute and the “E” shortly after.
See if you can get some fuel delivered and try bleeding the system. If that don’t work you’ll have to have it towed in.
