CA_Traveler
Aug 04, 2021Explorer III
Add the correct transmission fluid. You have water in the tank and algae. Be prepared to change filters often. ie Carry spare diesel and tools to change BOTH engine filters. DO NOT BLOW OUT THE FILTER WITH COMPRESSED AIR. The filter did it's job, discard it and don't risk using a ruptured filter.
DO NOT MONKEY WITH THE GEN FILTER. Find the correct filter. Your fuel filters should be available at truck repair shops.
Get professional advice because your problems could be a lot more expensive if the algae problem and low tranny oil (YES it's oil) is not resolved.
