TugCE
Oct 04, 2016Explorer
Engine Choice
So, I have been looking at several Class A's and have a question. If you had a choice of purchasing and RV from someone that you know with a GM 8.1 or an RV on a lot with a Ford V-10, which would y...
If you had a choice of purchasing and RV from someone that you know with a GM 8.1 or an RV on a lot with a Ford V-10, which would you choice?
Both of these RV's are almost identical and I was really getting ready to pull the trigger on the V-10 when the one with the GM Engine popped up.
There are things that I do like about the Ford Engine but the fact that I can know just about everything about the GM powered rig is making me question myself. The Person that has the GM is the type that was really picky about his rig.
Thanks
