TugCEExplorerOct 04, 2016Engine ChoiceSo, I have been looking at several Class A's and have a question. If you had a choice of purchasing and RV from someone that you know with a GM 8.1 or an RV on a lot with a Ford V-10, which would y...Show More
ArchHoaglandExplorerOct 04, 2016GM 8.1.I have had two of them, lots of power. Never had a Ford so I can't make any comparisons.Some things I would check though, based on my experience of 12 years and 80,000 miles are:The Actia dash gauges...make sure the LCD that tells you what gear you are in is readable.Make sure the Bosch brake recall has been done. Exhaust manifolds have been a problem with mine...in the shop three times with broken bolts, etc.
Related ContentPotential engine overheatingNear engine overheating gaugeSide Patio ChoicesHitch choiceDP engine choices and emissions
