TugCE
Oct 04, 2016Explorer
Engine Choice
So, I have been looking at several Class A's and have a question. If you had a choice of purchasing and RV from someone that you know with a GM 8.1 or an RV on a lot with a Ford V-10, which would y...
JayGee wrote:
Not knowing the model years of either or chassis of the GM makes it difficult to advise. However, if the GM has the yellow button parking brake that is a negative to me. I had one on a P32 chassis and I did not like it. If it is a W## Workhorse the Bosch brakes should have been recalled and repaired. I never drove a W## chassis so my opinion on how they drive excludes it.
I think the Ford spark plug problem was about year 1999.
I have had both, I like driving the Ford better but it does not matter as much as the floor plan to me. If I were buying again I would probably prefer the Ford if the floor plans and money were the same.
There's my two cents worth. Good luck on your choice.
