bobndot
Jul 07, 2022Explorer III
mikestanton wrote:
Access panel? Is there an access panel in the "footwell". Do I need to look up under the dash to find it? Thank you so much for the help.
It might not look like a conventional cover but the fuse box does have tabs on the front that you can lift off the front part.
Squat down and use a flashlight , as you look at the brake pedal, its to the left of the pedal on the firewall.
38,782 PostsLatest Activity: Sep 10, 2026
