SJ-Chris
Jul 08, 2022Explorer II
mikestanton wrote:
I have a 2004 29" Gulfstream on a E450 chassis. It has the V-10 motor. I can't find the interior fuse block, lights AC, etc.
It isn't next to the steering wheel next to the brake pedal under the dash.
Can anyone help me locate it?
There should be a fuse panel under the steering column near the emergency brake.
There is also a fuse panel in the engine compartment with lots of fuses for various things. On my RV (e450 V-10) it is located on the driver side front corner (closest to the grill) under the hood.
Then of course there is the fuse panel in the RV house section and that is often times located near the rear bed or under the dinette.
Good luck!
Chris
38,782 PostsLatest Activity: Sep 10, 2026
