Desert_Captain
Sep 08, 2014Explorer III
ronfisherman wrote:
Consider the ScanGaugeII. It not only reads the codes but also gives you many engine and transmission data instantly. It does cost more than a plain OBDII reader.
Codes are readily available on the internet.
X10
The Scan Gauge will do so much more than a simple code reader. The improvement in fuel economy from merely paying attention to the average/real time mileage displays nets most folks about an 8 to 10% n crease in mpg. These savings will pay for the SC very quickly.
The SC has 4 displays that can be switched out with just a couple of keystrokes. I run with trans fluid and engine coolant temps displayed (along with the realtime and average mileage).
Knowing the trans fluid temperature is priceless and enables me to better utilize the Tow/Haul mode and greatly extend the working life of the transmission.
Last time I looked you could get the Scan Gauge II (for gas or diesel), for $139 on Amazon but often it is even less.
:B
38,782 PostsLatest Activity: Sep 10, 2026
