dougmac
Jun 24, 2013Explorer
It is possible that it has had some kind of a front gear train failure. The oil pump and fuel pump are both driven off of the timing gears. Unfortunately, if it has experienced a failure that would allow the camshaft to come out of time with the crankshaft, you may have damage to the valves.
Good Luck
Doug
Good Luck
Doug
