CalD's avatar
CalD
Engine missing
I have a 2000 Ford V10 310 hP. On Memorial Day weekend I developed a fuel leak above the fuel tank. We lowered the tank and found that a critter had chewed the rubber line through. The line was replaced. The first trip out it ran great as usual until I started up a grade and it shifted out of overdrive and the RPMs went to 3500 then the engine started to shake and miss fire, after dropping down to normal running RPM of 2400 it ran smooth again. This went on at all up hill times. Any ideas on what is causing this. CalD
