wolfe10
Aug 21, 2013Explorer
Call Freightliner in Gaffney in the morning with your VIN and ask them if disconnecting should default the fan to high. If true and that did not turn the fan, next thing would be to verify that the fan motor is not frozen up-- can you turn it by hand?
Also, verify with Freightliner that the pump that supplies the fan motor also runs the power steering. Some applications use a separate pump and reservoir for the fan motor.
Do you have a filter in the system-- might change it.
