thriftydutchExplorerAug 10, 2015Engine overheatingCan old antifreeze cause the engine to overheat. The tester shows that it is still okay for minus 45 degrees celsius.
enblethenNomadAug 10, 2015When was the thermostat last changed out. It could have failed in partially closed position.
Related ContentPotential engine overheatingNear engine overheating gaugeEngine overheatingTranny overheatedCat 330 Engine Overheating
