tomkat4725's avatar
tomkat4725
Engine surge tank
Purchased a 3 year old Tiffin Phaeton 36QSR with a 2013 XCR-Series Freightliner Custom Chassis. ISC 8.3 Cummins engine. Have owned it for a year and have 27,000 miles on it. This unit has the radiator in the rear and a coolant surge/expansion tank sitting on top of the radiator. It is nearly impossible to view much of the engine side of the radiator or expansion tank. What concerns me is that the portion of the expansion tank (which is plastic or a plastic like material) which I can see has spider web lines running all over it. It is a semi transparent material. Also, it has a seam running horizontally across it which is brittle and crumbly. This tank doesn't look healthy to me. Anybody out there run across this problem?
  • Jim@HiTek wrote:
    On my '02, rear rad, Cat 3126, Freightliner chassis, my tank is showing some spider cracks and I'm getting close to replacing it (I've owned the rig since Feb. '16). In the meantime, I used Eternabond tape to cover the cracking area to get a few more months out of it. This summer is the target replacement time thoughRad & Cooling
    Jim, if it really starts to leak with pressure behind it, I don't think the Eternabond will hold it.
    Bill
    Bill
    I wondered about pressure too. But most owners who posted on various forums, said the tank began to 'weep' first so I didn't expect a catastrophic failure. I felt comfortable giving the Ebond a try.
    Incidently, I have a friend with an '04 Journey. Also has the same surge tank. Except her's was in pretty bad shape compared to mine. Was both spider cracked and crumbling like the plastic was rotten, but we were in Mexico and she wanted to wait until she got home to Vermont to fix it. So I did the Ebond patch on her tank and April '17 she drove from Baja to Vermont without a problem.
  • always good to replace those also
    but not what the discussion is about
    the 'surge tank' on a diesel has a pressure radiator cap
    it is part of the coolant flow system, not a reservoir for extra coolant
    when these go boom, the engine quickly pumps out all the coolant, its the same thing as blowing a hose or a rock thru the radiator
  • pardon me
    the amazon link, said reservoir not surge, and pictured a tank with a plain plastic cap
    reservoirs, take overflow and are not pressurized
    one question .. where does it attach on your radiator ?
    to another 3rd or 4th hose connector on the radiator tank
    or too the little nipple at the radiator cap ?
    just trying to understand the Ford cooling system
    the surge tank on my cummins has (3) hoses attached coolant goes thru the tank pushed by the pump
    there is another small reservoir to use for topping off the coolant
  • capThe plastic cap is a 16 lb rated cap, it's the only cap on the system. The radiator is connected to the bottom of the bottle on a 1" hose. I don't know that the system has any kind of overflow bottle and couldn't find any google diagrams of it on line. this tank has 2 hoses, one small and one large. Antifreeze flowed from both when I switched it.
