dons2346
Jul 16, 2013Explorer
180 is low. The range should be in the 195 to 200 range and those numbers will climb as you head up the hill. Is this a side radiator? If so the hill climb temp should peak out around 210 and then the fan controller will come into play and reduce the temps. If a rear radiator, then you will have to raise engine RPM to increase air flow over the radiator and turn the water pump faster.
38,782 PostsLatest Activity: Sep 10, 2026
