rgatijnet1
Aug 30, 2016Explorer III
frankiebIII wrote:
I checked the radiator and there are a few bent fins and it is somewhat black but I can see through it. I'll clean with simple green today.
There is also an electric outlet in the back engine compartment with a plug hanging nearby but not plugged in. I'm assuming that is for a device that heats the engine in cold temps correct?
Use the Simple Green Extreme, not just the plain Simple Green. The SG Extreme is made for aluminum and the plain SG will start to corrode metal if even a little bit of it is left when you rinse things off. Since it is next to impossible to thoroughly rinse a radiator, use the right product instead of possibly creating another problem.
