wolfe10
Aug 30, 2016Explorer
Is this a rear radiator?
If so, you need to clean the FRONT of the Charge Air Cooler from the FRONT (access from bedroom/closet--whatever gives you access to the front of the fan shroud).
The only exception is if you have a "stacked" CAC/radiator instead of a "sandwiched" CAC/radiator with the CAC in front of the radiator.
Cleaning from the back with a sandwiched cooling package may make one feel good, but the VAST percent of the dirt and debris will have been "filtered" out by the CAC.
