aintnothin wrote:
teleman2 wrote:
Just replaced the starter on 2000 damon ultra sport. When turn the ignition switch sometimes it would start other times you would have to do it 2 or 3 times. Replaced the starter solved the problem. Oh it uses the battery's to start.
Glad to see someone with the same brand! I'm going to start with a couple of the easiest, the starter solenoid and the nuatral safety switch relay. If you could point me to those? I took the batteries in and had the tested a Napa and they are good.
The neutral lockout switch is in the transmission, but closes a relay in the starter circuit.
Freightliner can tell you where it is on your coach.
Jeff
