tatest
Nov 06, 2013Explorer II
Engine braking works with any gas engine and automatic (or manual transmission, not a RV option). Options like Ford's tow-haul and Allison's grade retard automate the process a little, but you still need to understand what you are doing, e.g. engine braking is proportional to RPM and works only with throttle closed.
Everything I have other than the RV is manual transmission, about 1/3 of my braking is by engine. Most modern car automatics will do almost as much, no effort on your part, if you drive reasonably, get off the gas early as possible when there is a stop or slowdown ahead. Hybrid fuel savings depend on the driver learning this.
38,782 PostsLatest Activity: Aug 11, 2021
