DFord wrote:
A search for Dorman 742-206 on RockAuto returns Dorman 742277 as the current replacement. You'll need to cut the wires on both motors and put the old connector on the new motor with some butt splices. The motor itself is held in with 3 bolts. Easy swap.
RockAuto Listing for Dorman 742277 Window Lift Motor
https://www.rockauto.com/info/42/742-277-010__ra_p.jpg
Topic: Replacement motor for Kwikee steps
Great find. That is less than half the price from eTrailer. Looks like the armature shaft might be different. Sounds like you did the repair yourself. Is the shaft the same as the one you removed or did that issue have to be addressed? If the wiring harness is the only difference that won't be a problem.
I took pictures of the labels today. I'll have to go back and get more information and pictures tomorrow before I order it. Looks like I could maybe swap armatures if necessary, but that may mean I'm bringing the old problem along, to the new motor.
