LOG
Jun 24, 2013Explorer
Entry Door Striker Plate Adjustment
I need assistance adjusting the door latch on my 2007 Itasca Sunova 26P motorhome. If someone has adjusted their door latch or knows the procedure on how to adjust the door mechanism I would appreciate your help. Specifically, I need to lower the striker bolt. The striker bolt has an allen key slot in the end of the bolt, but I need to know if I need to access the rear of the striker bolt. There appears to be a plastic cover plate behind the striker bolt. Do I need to remove the plastic panel and access the striker bolt from the backside of the door facing? Thanks.
