Goldencrazy
Oct 22, 2015Explorer
bounder39zman wrote:
You probably have an answer from your repair shop by now, but I will weigh in anyway.....free advice. Being a Guardian will change symptoms/causes as it is diagnosed. Guardians will actually continue to run when they are not producing power, where Onan will shut down if no ac power being generated. Voltage regulator most common problem on these sets, but need to check rotor field brushes as high resistance here will cause short regulator life.
My new Onan ran and then stopped producing electricity but did not shutdown. It as a wire that had a shield slip and when we bounced it shorted. Tough to find and easy to fix but it required removing the generator from the coach and taking it apart as wiring was in the middle.
