tropical36
Oct 24, 2015Explorer II
bounder39zman wrote:
You probably have an answer from your repair shop by now, but I will weigh in anyway.....free advice. Being a Guardian will change symptoms/causes as it is diagnosed. Guardians will actually continue to run when they are not producing power, where Onan will shut down if no ac power being generated. Voltage regulator most common problem on these sets, but need to check rotor field brushes as high resistance here will cause short regulator life.
It sounds like you have some experience with Generac, but before going any further, I can't even get mine out of the coach, so if you think you can help me with this dilemma, please post on my new thread...5.5 Generac Generator Removal...and thanks in advance.
