the_bear_II
Aug 05, 2014Explorer
I was impressed with the product listed at the website below. It can be sprayed on or brushed on. A 1/8th thick coating will resist direct flame for an hour. In the test I watched the flame registered 1200 degrees and on the opposite side from the coating a temperature probe was only showing 86 degrees.
It's not cheap but works well and is being used by luxury yacht builders for fire and heat protection plus it does have some sound dampening properties.
http://www.noxudolusa.com/products/thermal-insulation-products/
There are some dealers in so cal listed that will apply the product for you
38,782 PostsLatest Activity: Sep 02, 2026
