Mr_Mark1
Aug 05, 2014Explorer
I just don't understand how a Camelot can be so much different than our Dynasty. It was 95 degrees today running across middle Tennessee. I had the genny running and two airs running (not the bedroom air, just the front and middle). Our ducts are all connected so the bedroom and closet, which has a vent, will get air conditioning.
It got so cool that I turned off the dash air for a while. Another thing I don't understand is that the OP said his electric cord was so hot he could hardly touch it. Ours is in the middle of the coach and has never been hot. I just don't understand how the coaches could be so different heat-wise.
Some people will open their rear engine door (once parked) to help release the heat (even though there is a built-in vent). But still, the Camelot sounds WAY TOO hot. It should be checked out.
Good luck,
MM.
Good luck,
MM.
38,782 PostsLatest Activity: Sep 02, 2026
