azrving
Jan 12, 2015Explorer
Check the oil filter to be sure it's tight. If it's quiet now and not knocking loudly you are probably ok. I have seen a lot of loose filters after oil changed.
If the oil is clean you dont need to change it again. Be sure it's up on the stick and check that filter. Do you know how to check the oil?
