- 352ExplorerTurn on the kegerator.
- AllegroDNomadSpace heaters. Do not turn on water heater if empty/winterized.
- CloudDriverExplorerX4 or 5 on 1,500 watt electric heater (on high).
Start generator, allow to run for 5 minutes to warm up, turn on electric heater for one hour, turn off heater and allow generator to run for 5 minutes to cool down. Shut off generator. - jplante4Explorer IIRun the dryer.
- ksg5000Explorerdouble post
- ksg5000ExplorerI use two electric heaters set on low - on different circuits. I let mine run for about two hours.
- Dale_TravelingExplorer IISpace heaters are your best potential loads. Makes for a nice continious load on the generator. Just stay with one heater per circuit breaker.
- w4phjExplorerIn addition to the above:
Turn on water heater
Turn on block heater
Switch refrig to elect
Turn on microwave with a large volume of water to be heated - wildtoadExplorer IIPut on a pot of coffee....
- 2_many_2Explorer III
4aSong wrote:
Me too, or use the heat pump or heat strip on the AC if it has one and the electric part of the water heater if equipped is another option.gbopp wrote:
I use a 1500 watt electric heater. Or two, depending on the size of your generator.
This is what we do.
38,707 PostsLatest Activity: Jan 05, 2014
