mike24ExplorerApr 17, 2015Exercising GeneratorHow often do you exercise the onboard generator, and do you put it under load and for how long. Do you use the a/c for load. Thank you
enblethenNomadApr 17, 2015One hour should be long enough under about 75% of rated genset. AC unit should provide this or a couple space heaters rated around 1500 watts.
Related ContentExercising generatorExercise my generator?Exercising the generatorDo you Exercise that GeneratorGenerator noise reduction
