- wolfe10ExplorerAs I posted above, one of the first things to check when the exhaust brake does not engage/transmission begin downshifting toward the "preselect gear", is the THROTTLE POSITION SENSOR.
If the sensor does not send the "throttle is closed" signal, the exhaust brake should not come on.
If you are not familiar with this, take it to someone who is. Having the wiring diagram for your system will save you time and $$$. - captron33ExplorerReposting this. Stll not working.
- captron33ExplorerYes my coach has a exhaust brake.
- wolfe10ExplorerHave you confirmed that you do have an exhaust brake.
As mentioned, the Cummins ISL could be ordered with either an exhaust brake, or for more $$ an engine compression brake (aka Jake brake). Also possible you have a VGT that acts as an exhaust brake.
Look at the exhaust manifold. If you have an exhaust brake, it will be bolted to the exhaust manifold.
Calling Cummins with your engine serial number would tell you exactly what you have.
Cummins 800-286-6467 - captron33ExplorerSorry,I don’t know how to do that. Traveling now near grand rapids,mi. For a couple weeks. I might give spartan chasis a call. Worth a try.
- wolfe10ExplorerDid you verify that the throttle position sensor IS communicating that the throttle is closed???
- captron33ExplorerHave not modified anything. I tried what you said to try. No change , not working at all. Was hoping some easy fix ….. like a fuse or cb. Very disappointed.
- wolfe10ExplorerIf the transmission shift pad does not change from "6" when you engage the exhaust brake, it is not working. That is one of the first step. When the brake was working for you, what was the pre-select gear/what gear did your shift pad change to when you engaged the brake?
Verify that your throttle position sensor is closing when you get off the throttle, because any throttle will cause the exhaust brake to not engage.
Again, a little confused as the 2006 Cummins 400 HP was the ISL, not ISC. Have you modified your ISC for more HP? - captron33ExplorerSorry, yes isc 400. When i activate the switch on my left , the light on the dash ( aux. brake ) doesn’t come on and no down shifting or drag is created. I will try what wolfe said. Thanks for the suggestions.
- larry_cadExplorer II
wolfe10 wrote:
And, very easy to verify if any type of engine brake is working: Use transmission down arrow to select a gear where you are close to the upper end of the RPM range. Turn engine brake on/off/on. Since the transmission is now a constant, easy to see if you have added braking HP.
Brett, thanks for that suggestion. Never thought of that.
Larry
38,782 PostsLatest Activity: Sep 10, 2026
