werni9's avatar
werni9
EXHAUST BRAKE SWITCH (When to turn on)
Having trouble understanding "Exhaust" brake use. At 50 mph, I turned the switch on as I approached a town with slower speed. It slammed hard in the rear and started slowing. It took about 5 seconds from turning the switch on until it engaged. At the top of a downslope, what speed can I turn the switch on? Basically, how does this all work? Is tranny selection come first and then turn on "exhaust" brake? I almost wrecked and don't travel anywhere but flat lands. Would like to drive some hills knowing how?
  • I don't use mine all the time...have been told, right or wrong, that there can be carbon issues from running them all the time. I also, don't really want it to brake whenever I let off the throttle. When on roads that are gently rolling or flat, I want the vehicle to gain some speed in anticipation of the next uphill segment. A gain of 3 to 5 mph means I need less throttle going up. The ride is also smoother without the engine brake grabbing the coach every time I take my foot of the throttle.
    I do use it in town, as it cuts brake usage when the speed limit starts dropping and between stops when in town. I also use it, to its primary purpose of going down steeper grades to let the engine slow the speed as opposed to riding the brakes.
    That's the way I use mine, both in the coach and when I had a diesel pickup truck.
  • Your profile doesn't show what you're driving. Guess I am also a novice since I've only had the diesel for over a year. I was told not to bother turning the exhaust brake off. I always drive with it on, and I find that it decelerates the rig when I ease off the gas even before I press the brake. Makes my drive very comfortable. Out here we have lots of mountains and hills, and if I keep my speed around 45mph going down the mountains (truck speed posted at 30 to 35 mph) I seldom have to touch the brake peddle as the engine brake slows my speed nicely.
    Happy Trails.
