Old-Biscuit
Jul 02, 2017Explorer III
Even in major utility power plants the generator slip rings/brushes needed regular routine maintenance
As for water heater circuit board....they are NOT a common item of failure.
Usually dirty contacts/loose connections/bent pins/bad grounding.
Yes they can fail....but just not common. Pretty robust and simple circuitry
