mgirardo
Feb 19, 2018Explorer
Our Greyhawk Class C came with the braided ones that Cobra21 mentioned. They worked fine for a couple years. One of the inner tires became hard to check pressure and just wouldn't take air. I removed the hub simulator and then removed the extension. After re-installing and removing a couple times and blowing air through the extender a few times, I was able to get it working again. I made sure the extender was on tight.
They worked fine until we replaced the OEM tires. We had Tire Man's dually valves installed when we replaced the tires. Tire Man's valve stems are great. They put the valve stems at an easily accessible place. Checking and airing up tires became much easier after getting the Tire Man dually valve stems. Worth every penny.
-Michael
-Michael
