Bordercollie
Feb 19, 2018Explorer
Confusion: Cheap screw-on valve extensions can leak and even lead to running soft and tire failure. Custom formed solid metal valve assemblies like Borg Dually valves need to be installed onto each wheel and do not leak, make checking and adding air easy. No need to remove beauty discs.They stay on wheels and are not changed out with new tire installations. RV tires are not rotated so they stay on same wheels. Not cheap, but worth it if you intend to keep the rig for some time.
