Harvey51
Feb 20, 2018Explorer
When we bought our 4 year old MH, I didn't buy special stems. The used Ford had plastic extenders on the valve stems and I managed quite nicely with pressure gauges like this and a similar inflation head for my compressor.
P
The straight on end is necessary for the inner wheel and the backward angle one for the outer s which must have the valve stem long enough to be close to the rim opening. I have had a service station add air twice and they both had the appropriate inflation tool. I rarely use my portable air pump but it is a comfort to have for sure,
I never had trouble that a plastic extender but a metal one I tried failed to close after I checked the pressure at a rest stop. I got the darn thing off quickly enough to limp to a service station.
With the first set of new tires I got Costco to install longer valve stems (rubber) and have never needed extenders since. I also decided to put regular valve caps on to keep things clean, using a short length of plastic tubing with a wood dowel holder to take off and put them back on. It takes about 5 minutes to check all the tire pressures. Would be a little faster if I marked the spot on the rim where the stems are located. The Costco installer thoughtfully installed the wheels so both inner and outer valves are in the same big rim opening.
PThe straight on end is necessary for the inner wheel and the backward angle one for the outer s which must have the valve stem long enough to be close to the rim opening. I have had a service station add air twice and they both had the appropriate inflation tool. I rarely use my portable air pump but it is a comfort to have for sure,
38,782 PostsLatest Activity: Sep 10, 2026
