j-d
Feb 20, 2018Explorer II
I'd venture Charles' valves weren't installed properly. As he noted, the instructions say you have to bend that long one to get it through the hand holes and the rubber stabilizer if applicable.
I, too, took wheels off and carted all seven to the auto shop on the local Navy base. We went over the Instructions together stressing bending the stems, stacking outer wheel onto inner (and I brought a Simulator as well) to check alignment, and LocTite to keep the mounting nuts tight. Zero problems. I doubt there are many wheels harder to align valves to, than the Fords 1992-2007 with those tiny round holes. Even with simulators that have still smaller holes, my valves line right up. I mount our wheels with the two valves opposite minus one stud. That's because there's a 7/16" hole in the 8-lug pattern between two holes. I threaded those holes 1/2" SAE to match a lug bolt from a trailer. I can "drive" that lug bolt and force stuck wheels off of the hubs. If I lined the two wheels up with valves opposite, those threaded holes would line up. I'd be screwing the wheels together instead of pushing them apart...
38,782 PostsLatest Activity: Sep 10, 2026
