HighLonesomeExplorerAug 28, 2016Exterior Color and Inside Temperature...OK.... I need some help here.... about exterior color vs temperature inside. I will be 3/4 timing to start with so I will be living in my B most of the time. My intention is to follow the seasons ...Show More
NaioExplorer IIAug 29, 2016That's a good point that you might want ac when driving but not when parked. That engine does put out a LOT of heat.
Related ContentRV inside Temperature and Refrigerator temperatureTemperature inside rvQuick connect exterior shower hose doesn't connect.Replace insulation inside heater column.Darker exterior color cause higher temps inside?
