Sully2
May 28, 2014Explorer
tropical96 wrote:
Questions:
Does my Tropi have a solid front axle or independent suspension?
Does my Tropi have air bags? If so, where/how do I check/add air pressure?
Can you determine or suggest the probably cause of the single side tire wear?
Any idea on costs if I have to go beyond alignment to things like ball joints, tie rods, steering damper, wheel bearings, bushing, and shocks?
Front independent suspension
yes it should have air bags with coil front springs
You crawl under the coach and check the stems protruding from the bottom of the coils
How BADLY your front is , is ??? but you definately need and alignment along with???
Star away from RV joints....check at a LARGE truck location
